C43 McLaren
flango
Hardcore MB Enthusiast
Gods own country
Mercedes SLK R171
From the description: "...390BHP electronic conversion...". I wonder how they did this and what was used.
I did post this somewhere. Mclaren did mod a few C43's for people, one was a popstar. The electronic mods were the ECU's were removed and replaced with bespoke ones, thats how you can tell if its a Mclaren car or not the electronics have Tag Heur markings and numbers not MB.
If that were a Mclaren car it would be worth thousands as IIRC there were only 3 C class done
noogieman
EU
I loev MB
does it mean this c43 is a fake?
whitenemesis
MB Club Veteran
Lexus RC300h F-Sport 2019
The datacard
Ignore the SA 744 Soft top reference, common input error for the delivery date, it should read 744U Brilliant Silver Metallic
SA 588A refers to the leather colours
Datacard
Identification number: WDB2020332F766791 9
Chassis
Sales designation: C 43 AMG
Order number: 0 8 537 15045
Delivery date: 06 07 1998
Paint code 1: 744 DARK BLUE SOFT TOP FABRIC 5010
Equipment: 588A No code designation available
Engine no.: 113944 60 003254
Transmission: 722631 01 010050
SA code
220 PARKTRONIC SYSTEM (PTS)
221 LEFT FRONT SEAT, ELECTRICALLY ADJUSTABLE
222 RIGHT FRONT SEAT, ELECTRICALLY ADJUSTABLE
240 OUTSIDE TEMPERATURE INDICATOR
249 AUTOMATICALLY DIPPING INSIDE REAR VIEW MIRROR
345 RAIN SENSOR
414 ELECTRIC TILT/SLIDE SUNROOF IN GLASS VERSION
441 ADJUSTABLE STEERING COLUMN
461 INSTRUMENT WITH MILES IND. AND ENGLISH LEGEND
472 ELECTRONIC STABILITY PROGRAM (ESP)
500 OUTSIDE REAR VIEW MIRROR LH AND RH FOLDING
540 ROLLER BLIND, ELECTRIC, FOR REAR WINDOW
551 ANTI-THEFT/ANTI-BREAK-IN WARNING SYSTEM
570 FOLDING ARMREST, FRONT
580A LEATHER, CONDOR
581 AUTOMATIC AIR CONDITIONER
584 ELECTRIC WINDOW LIFTER, 4-WAY, V 124, 6-WAY
600 HEADLAMPS - CLEANING EQUIPMENT
611 EXIT LIGHTS FOR DRIVER DOORS
617 LAMP UNIT: XENON HEADLAMPS ASSYMMETRICAL
668 PACKAGING FOR SHIPPING VEHICLES WITH TIE-DOWN HOOK
673 HIGH-CAPACITY BATTERY
682 FIRE EXTINGUISHER
750 MB AUDIO 30 RADIO WITH VK/RDS
772 AMG STYLING PACKAGE-FRONT SPOILER, SIDE SKIRT
774 SHELL MODIFICATION FOR AMG-WHEELS
809 AEJ 06/1/M/X
810 SOUND SYSTEM
819 CD CHANGER
833 INVALID/GREAT BRITAIN,ADDITIONAL PARTS
873 SEAT HEATER FOR LEFT AND RIGHT FRONT SEATS
875 HEATED SCREEN WASH SYSTEM
882 INTERIOR SAFEGUARD/TOWING PROTECTION
956 EQUIPMENT PACKAGE SPORT
984 COC DOC., DELETION OF VEHICLE REGISTRATION DOC.
Other
Lamps: BOSCH
andy27168
Southampton
1997 C230K, 1999 C43/55 AMG
Regardless of whether the McLaren conversion is true or not its a very highly specced car if the rust is only cosmetic then a good buy I reckon.
rajinder_1
Midlands
01' Designo SL320 , 96' C36 AMG, 98' C43 AMG Estate 19' Focus & 96' ZX6R Ninja
Hi Guys
I saw this car advertised and all the questions i had got answered sort of on here !
but the MOT check history shows a tonne of rust see below!
looks like he has increased the price from is original £4200 to £6000
would have been nice to have but not with all the brown stuff !!!
Advisory notice item(s)
rear registration plate deteriorated but not likely to be misread (6.3.1d)
very strong advise floor corroded
Windscreen has damage to an area less than a 10mm circle within zone 'A' (8.3.1a)
light warning light on
both headlamps detiorating
Test date16 April 2015 Expiry date15 April 2016 Test ResultPass Odometer reading124,392 miles MOT test number5692 9610 5108 Advisory notice item(s)
Nearside Rear Tyre worn close to the legal limit (4.1.E.1)
Offside Rear Tyre worn close to the legal limit (4.1.E.1)
Front brake disc worn, pitted or scored, but not seriously weakened (3.5.1i)
Front Brake pad(s) wearing thin (3.5.1g)
Front Vehicle structure has slight corrosion (6.1.A.1)
Rear Vehicle structure has slight corrosion (6.1.A.1)
Test date2 May 2014 Expiry date31 May 2015 Test ResultPass Odometer reading116,604 miles MOT test number9954 3212 4179
Test date21 May 2013 Expiry date31 May 2014 Test ResultPass Odometer reading114,225 miles MOT test number4697 2164 3118 Advisory notice item(s)
Offside Obligatory mirror deteriorated, but not seriously affecting the rear view (8.1.2a)
heavy corrosion to floorpan and holed outside prescribed areas
plastic sill covers fitted
Test date13 May 2013 Test ResultFail Odometer reading114,009 miles MOT test number7382 1313 3157 Reason(s) for failure
Offside Rear Subframe mounting prescribed area is excessively corroded (2.4.A.3)
Offside Front Seat belt anchorage prescribed area is excessively corroded (5.2.6)
Test date16 May 2012 Expiry date31 May 2013 Test ResultPass Odometer reading106,896 miles MOT test number8286 2783 2109 Advisory notice item(s)
nearside rear outer position lamp not working
plastic sill cover fitter
both front floors corroded
Test date16 May 2012 Test ResultFail Odometer reading106,896 miles MOT test number8297 2783 2149 Reason(s) for failure
Offside Front Front position lamp(s) not working (1.1.A.3b)
Test date11 May 2011 Expiry date31 May 2012 Test ResultPass Odometer reading101,420 miles MOT test number3554 6133 1148 Advisory notice item(s)
nearside wing mirror glass slightly deteriorated
nearside rear outer position light not working
corrosion to offside rear chassis rail, offside outer sill and nearside front floorpan around jacking point
Test date4 May 2011 Test ResultFail Odometer reading101,295 miles MOT test number2167 9442 1163 Reason(s) for failure
Direction indicators flashing more than 120 times a minute (1.4.A.2g)
Centre Rear Statutory seat belt missing (5.1.1)
Test date27 May 2010 Expiry date31 May 2011 Test ResultPass Odometer reading95,597 miles MOT test number9147 0764 0107 Advisory notice item(s)
advisory on perivous test no850008030134
welding repair heavily under sealed
Test date18 May 2010 Test ResultFail Odometer reading95,343 miles MOT test number8500 0803 0134 Reason(s) for failure
Nearside Front position lamp(s) not working (1.1.A.3b)
Offside Seat belt anchorage prescribed area is excessively corroded (5.2.6)
corrosion to both rear door shuts
heavy corrosion to both floor pans
corrosion to offside rear chassis rail,offside rear inner and outer sill
corrosion to both rear inner and outer wheel arches
both rear tyres worn heavy inner edges
offside front tyre worn on edges
corrosion to both front inner and outer wheel arches
nearside front tyre worn heavy on edges
front brake pads worn
heavy corrosion and hole offside front floor pan around jacking point not within prescribed area
Test date19 May 2009 Expiry date31 May 2010 Test ResultPass Odometer reading86,025 miles MOT test number8004 1953 9180 Advisory notice item(s)
front discs slightly lipped
both floors have surface corrosion
Test date20 May 2008 Expiry date31 May 2009 Test ResultPass Odometer reading78,014 miles MOT test number2736 5184 8413
Test date20 May 2008 Test ResultFail Odometer reading78,014 miles MOT test number8318 5124 8109 Reason(s) for failure
Offside Side repeater not working (1.4.A.2c)
Nearside Headlamp aim too high (1.8)
Offside Headlamp aim too high (1.8)
Test date1 June 2007 Expiry date31 May
