C43 oil leak around power steering pump
amg3.6
UK
C55 Amg White W202
I have noticed an oil leak around the power steering pump? Any ideas where its exactly coming from as i can't really pin point the leak. It might be washers or seals any part no's would help
I cleaned it up with some de greaser and the oil has appeared again
Will try and post a pic when i get a chance
BlackC55
Portsmouth, Hampshire.
E55K SL500 E300Hybrid E250X3 Viano C55 E450Cab A180 Smart 44 Brabus
Oil cooler seals 100% They go between the cooler and the filter housing.
Did mine yesterday.
OP
OP
amg3.6
amg3.6
UK
C55 Amg White W202
Thanks olly for your quick reply have you got a part no?
Where is it located exactly? So the pump is ok?
DogWagen
Peterborough
BMW E91 325d and Alpina E46 B3s. Still miss my C43 AMG Estate - Azurite Blue
Oil Cooler Seal Replacement - How-to
There's an old but excellent how-to thread on MBWorld from nitrogenbalance with pictures on this subject. Have a look at Leaking Oil Cooler - MBWorld.org Forums I think it has the part numbers listed.
From what Nitro' says, the seals are v expensive in the US - be interesting to see what Olly paid down south....
Mike
OP
OP
amg3.6
amg3.6
UK
C55 Amg White W202
Checked around the oil cooler no leaks visible?
BlackC55
Are you sure?
There is a little plate just below it on the front cover, they can leak too.
OP
OP
amg3.6
amg3.6
UK
C55 Amg White W202
Yes olly had a look all around the oil cooler no leaks even the belt is dry
OP
OP
amg3.6
amg3.6
UK
C55 Amg White W202
The little plate you reffering to is it part of the cooler i could'nt see under the oil cooler if its located below it
BlackC55
No it is below that. It is on the engines front cover.
OP
OP
amg3.6
amg3.6
UK
C55 Amg White W202
I will have a look on sunday. I also have some oil coming above the sump pan on the left side any ideas? I think it might be sump gasket?
BlackC55
Possibly be the sump. They dont often leak though.
OP
OP
amg3.6
amg3.6
UK
C55 Amg White W202
I will have a look on sunday its either that or the rocker seals above will have to investigate thourghly
