A few months ago I took the C43 on a track day (the brakes are completely standard) and did not have fade problems but the brakes got very rumbly as the day wore on. I believe the mostly likely cause of this was uneven pad deposits on the discs?
After some months of normal driving the rumble has subsided in normal use. I need to go do some high speed heavy stops to check if it has completely gone. Here is what my pads and discs look like now. Are the crumbly looking bits along the edges of the pads a worry and/or sign that I should replace them?
Thanks,
Brad
Thanks,
Brad
