C55 and CLK front wing same or different?
terrymcg
Perth, WA.
W164 ML 320CDI
After a bit of help if anyone knows...
I need to replace the front wing on my C55 and just wondered if it is 100% the same as a CLK W209 front wing? The only reason I ask is they have different part numbers? Or is that just a case of how MB list them?
Cheers.
Terry
I would be surprised if they were the same; the CLK is based on the E-Class.
Ah , but the C55 has the CLK front end to accomodate the V8 ... ;)
Not sure on the wing though.
Might be a longer panel from the arch to the door ?
So you reckon for a new wing I would have to buy the specific C55 one, oh well that will cost a few £'S!
Not the same. You will have to buy the one intended for the C55.
Nope. C-Class.
C/A208 -- W202
C/A209 -- W203
The c class and clk has the same suspension but the panels are different.
But I always thought the C55 used the CLK front end, hence why I thought the wings were the same??
They use some of the same parts but doubt the wings are the same.
CLK based on an E-Class? Really?
Based on the C Class chassis, but interior & fittings etc more in keeping with an E class than a C class, just like it's replacement the E class coupe, also based on the new C class chassis but more E class inside.
Russ
