brucemillar
- Nov 18, 2010
- C55 AMG Wagon - W124 300te 4matic Wagon - BMW 4.8is X5 E53 - SWB Pajero 3.5 V6 24v
Folks
Do you know if the W203 uses a daul or separate washer pump for the rear screen?
I ask because by rear washer is not working.
If I remove the nozzle from the spigot and push the washer button a tiny amount of water attempts to drip out the end of the pipe.
The nozzle is not blocked or frozen.
The spigot is not blocked (I can get a wire down it for about 10")
There is no water leaking into the car from the tailgate, rear cubby or front passenger footwell.
So I am assuming that the lines are all connected. When I push the washer button, I can hear the pump running.
I have also tried blowing from the spigot with an air line?
