C55 Wagon W202??
Just a 4.3 with a different cover I’d say. No mention of an engine swap, but it does look like the cover you’d find on some of the other early M113 5.4s (maybe S/CL or ML?)
Perhaps the original was broken? Because if you were swapping in a 5.4 you’d normally use the original cover anyway?
  • Like
Reactions: Abb
Just a cover, lets face it most have the badges on the original ones are missing or broken.
even with the covers off you wouldn't tell the difference between a 4.3 or a 5.4, unless like mine the 5.4 still had the vacuum actuators for the air pump on the front of the engine, which the C43 never had. I left mine on otherwise I would of had to blank the holes off.
  • Like
Reactions: Abb
Rather a lot of silicone spray has been used on the interior, which always puts me off; it's a favourite of dodgy small-time dealers. I don't personally like the finish of the wheels, but that's just me, and the rest looks fine.
It probably has about 145k miles on it, and the recent MoT history is bad, but the only real problem was corroded sills, and they're sorted now. I don't know anything about the W202, but wonder how likely it is that there is plenty more rust in non-MoT tested areas?
Nice C55 but I like that red thing in the garage more.
