C55 wants to stall and sometimes it does.
Tony
Brilliant. Thank you.
In your opinion. Would these (they are the ones I am talking about) cause a P0102 MAF error?
104, 107 are not fitted to your engine Bruce.
140 part number is: A1120180482.
Tony
Yes you do have 170 & 152.
All the numbers in shaded boxes are not applicable to yours.
I'm thinking they can only do good but I fear will not fix the error, which points to the actual MAF itself. Strange it started when I pulled off the air box. But I see no broken wires or disconnected pipes.
Well I now have the nice new pipes all ready to be fitted. I had to move the car this morning. Started her up and.......
NO EML and NO STALLING.
Ran her up the road and all is good. Switched on / off a few times and all is still good.
Confused am I. I will replace the breathers and see if I can spot a damaged wire to the MAF but previous inspections showed no visible damage.
I recently rescued a friends Integra Type R that had been sat for a year. Initially it wouldn't idle at all.
Once the oil was changed and it had a good thrashing it was fine. Cars like to be driven and sulk when you neglect them for a while :)
