C63 507 - Brake Pad and Disc Part Numbers *please*
Widowmaker507
Buckinghamshire
C63 507
Hi all,
I know that this has probably been posted elsewhere, so apologies if I am covering common ground here. But I will need to replace the pads and discs on my C63 507 and I'm looking to do it as cost effectively as possible with Mercedes OEM parts [installing through an Indy]
If you could let me know what the part numbers are for front and back, discs and pads, I would be grateful.
Thanks!
I usually call MB Edinburgh East and they always give me the part number. I have been a customer there for years so that usually helps.
Check out what Spider said visit Mercedes Benz Newcastle they do have an Ebay shop, leave the seller a message what you need along with vin number to get the right parts for your car . I use them a lot for my parts ..
You do not need the part numbers - just the Registration or VIN.
Ring Grimsby and ask for Thomas in parts.
Buy the Brembo's 2 piece Floating disc 360mm from Autodoc.
Cheaper than the factory 1.5 (techinically non floating) disc.
Slight weight saving and handles better.
£375 autodoc less delivery 2 piece brembo 😀
If you catch a 40% day (the discount is often bigger inside the app) then they're more like £275 each.
My mistake I've just put them in my basket to check and it is for 1 disc 🙄
The percentage discount isn't to be believed, the list price changes daily, and so does the discount level.
One day last week they were less than £270
Ignore the list price and discount percentage and look at the bottom line.
I paid £280.74 x 2 delivered.
@Muckypaps that's very much true for eurocarparts but Autodoc the base price changes less and the discount % actually makes a difference. I had a basket of brakes ready to go for a couple of weeks and it was over £100 more when the discount was 20% compared to 40%.
Totally anal but we all have our crosses to bare. All screenshots available on request
29/01 £509.10 -40% £305.46
31/01 £471.85 -22% £368.04
08/02 £456.14 -37% £287.37
09/02 £455.15 -34% £300.40
10/02 £454.81 -28% £327.46
10/02 £431.58 -35% £280.53
11/02 £455.15 -35% £295.85
07/08 £452.37 -22% £352.88
21/08 £357.37 -22% £357.37
You must have needed them to watch the prices like that . Good on you ,
