bravo05
- Sep 8, 2013
- Merecedes Benz C63 507 edition
Hi guys,
Unfortunately had some trouble with my 507 yesterday, ended it up with it catching fire!!!
I came to a stop and saw a whole load of smoke, i was trying to quickly reverse but then saw a massive flame so i switched the engine off.
As you see there was flames coming from underneath.
We managed to put the fire out but i feel there is some major damage, as the throttle stopped working, there is wiring burnt, the undertray is burnt, the coolant bottle ruptured so the car lost all its coolant and the steering arm boot has burnt.
I feel the last item, the steering arm boot may have been the cause of the fire, i had work done on the car from a genuine MB dealer and i feel this work was not carried out correctly.
From what I and others have seen the boot has split or come off and then the grease has been exposed to the large heat from the manifold thus causing the fire.
The car has been towed away to be returned to MB and have a full investigation into the cause.
If anyone has any advise on what happens next I would appreciate it, as i'm totally shell shocked that a 70k car would catch fire.
