C63 advice needed
jraw4
911 and Golf GTD
Hi all I'm just in the process of buying a 204 c63 I've found a nice one which has one owner and just 23000 miles on the clock, it's also at a merc main dealer. However it's just had its front discs and pads replaced!!
Seems very early in its life to have had its discs replaced, should I be concerned about this?
Cheers all
woodyc63
C63S wagon
I had a 204 c63 ppp which i sold at 30000miles and discs were fine however i have heard of standard cars having early disc replacement. As you are buying off a merc dealer with a warranty i would take it as an advantage as they cannot sting you for new didcs and pads at your next service!
ash59fifty-uk
The shire
C204 C63, VW Transporter
Considering that's a saving of nearly a grand I wouldn't even need to look twice, lol
JattAmg
Sl65
jraw4 said:
Hi all I'm just in the process of buying a 204 c63 I've found a nice one which has one owner and just 23000 miles on the clock, it's also at a merc main dealer. However it's just had its front discs and pads replaced!! Seems very early in its life to have had its discs replaced, should I be concerned about this? Cheers all
They would not normally require changing at 23k miles, I know of a car on 60k miles that has seen track time still on original discs.
ecain63
Bournemouth
'62 C63 PPP Saloon. Red. V5 Map. Remus exhaust. 181mph at Vmax stealth
Maybe the car had been sat for a while and the discs corroded? Could just be a pre sale prep, which given the front discs on the non ppp cars are cheap as chips is no huge ask.
Osgee
C63 AMG Sold, Now W211 E55
Could have been warped discs, my 63 had warped discs when i bought it at 38k, common on autos as after heavy breaking people can sit at the lights on the brake compounding all the heat into one location warping the disc.
RJ C63
C63s Saloon
Yep would agree.
OP
OP
J
jraw4
911 and Golf GTD
Thanks guys I'll have a good chat to the dealer but I'm feeling like this one is a no!!
JimmyR
W212 E63S
I wouldn't give up on it. Brake wear like this at this mileage would not be unheard of, particularly if done plenty of stop start city driving and the occasional more spirited drive.
Track day drives can chew through a set of pads in one session and rotors last maybe 2 sets of pads. If this car has been on a track and front pads and rotors have lasted this long then it has only tootled around.
Jame5
RRS
Don't forget dealers are keen to make money so could have advised the previous owner to replace pads and discs. I was advised it too on my old Range Rover for it's first service. I declined. Second service I wasn't advised. Pads must have grown material.
PhilT
C63 AMG Saloon
People saying its been tracked. Ive had mine since new and drive it like any other person would but done no track days and replaced mine at 24k. Most people including myself replace disks when the pads are low so its more than likely a good looked after example.
mounty3279
Huddersfield
C220, replaced by a C63 W204
Get it bought...
