C63 Coupe Tyre option
JohnDeere8530
that cant be right as the 30 is the aspect ratio, ie tyre wall heights are 30% the width of the tyre ? Increasing width and keeping same aspect ratio will lead to a slightly taller tyre
marc.l
E55 wagon
They would have a 3.3 mm extra hight in the side wall . It would not cause a problem .
JohnDeere8530
ok we agree the height is changed then. Being thick here............ how does the tyre pressure device work, I thought it detected minute changes in rolling diameter ? I understand this is a very sensitive device. Also would it affect things like traction control etc ?
marc.l
E55 wagon
It would be fine , 3mm is less than the difference between new tyres and worn tyres .
G.P
Leon & Sprinter
currently have 255/30/19 on the back of my 63
Tyres are knackered, it seems from this thread that 265/30/19 are an option but surely this will affect ride height fractionally and monitoring systems ?
Yes it will affect the height of the sidewall. You should remain within 3% of the rolling radius.
255/30/19 = 1939mm
265/30/19 = 1957mm
So your within that tolerance.
ABX
C63
Went up to 265 30 19 Michelin Pilot Super Sport on rear and they transformed my C63 - no more dire lack of rear end Grip - also went up to 245 on the front and no more understeer in the wet - makes a HUGE difference!!! Also even had improved ride which means better traction
AkisGr
CLS 320 with Brabus D6 and KW SC
265 is the width
30 is the tyre profile
19 is the diameter
255/30/R19 are the same as 265/30/R19 only wider.
S
Well,no they ain't. 30 is the percentage of the width(255 or 265,or any numbers).
So 255/30/19 has 76.5 mm hight(profile) and 265/30/19 has 79.5 mm hight.
Its nothing really,but aint the same. Would be noticable on much larger or narrower tyres. (275-285).
PS. I just saw after my comment that other members had already clarified it.
