C63 front tyres - 245 30 19 - wrong ones
SeeSixty3
Folks
Like an absolute numpty, I ordered 245 30 19 Michelin PSS from camskill instead of 2453519 to try and go slightly wider on the front of my c63.
Looking at the two tyres, there seem to be some diameter differences and circumference variances.
Can I still fit them? Not worried about speedo but more look, handling etc
What do you think!?
Can't return them as it was my fault.....
CB
renault12ts
MB Club Veteran
2005 W215 CL500.
What's on the back?
If the correct tyres are on the back I'd say no. You will have problems with cruise control. The diameter is an inch smaller than the 35s.
renault12ts
MB Club Veteran
2005 W215 CL500.
On the back - 265 30 19
There's only 6mm difference in the sidewalls...you should be ok. Given that the rears will wear quite quickly there probably isn't even 6mm in it.
Alex
S65, CLK55TT (WIP) & RR 5.0 SC
Folks
What do you think!?
CB
You've ordered a lower profile, same width tyre to go wider. How exactly did you work out the "wider" parameter? Sell them on eBay and buy the correct size.
renault12ts
MB Club Veteran
2005 W215 CL500.
If he orders a 245/35 there will still be 6mm difference in tyre wall front and back. To be precise with the 245/35 the difference will be 6.25mm.
I think 265/30 on the rear is wrong. 285/30 on the rear and 245/35 on front would be best. IMO.
OP
OP
S
SeeSixty3
Actually, The plan was to go up from 235 35 19 to 245 35 19. By mistake I ordered 245 30 19.
Does that change your question?
OP
OP
S
SeeSixty3
I assume you are aware of standard sizes?
235 35 19 front
255 30 19 rears
My plan was to go up to 245 and 265 - general advice on this forum, tried and tested!
Does that help?
renault12ts
MB Club Veteran
2005 W215 CL500.
The 235/35 is very close to the diameter of a 265/30. The 245/30 widens the gap, but not significantly. You'll be ok the gap is only 0.25 mm greater than the standard ones you've posted above.
Alex
I wouldn't have a question if in your very first post you didn't say you ordered 245 instead of 245.
This is great. Now if only you could tell the OP how to mount it over the rear 9J rim.
renault12ts
MB Club Veteran
2005 W215 CL500.
He said he ordered a 245/30 instead of a 245/35...I don't see your problem. His existing tyres are 235. He was merely querying the profile ratio.
You seem a little touchy this morning.
OP
OP
S
SeeSixty3
Quite right.
I assumed you would have joined the dots when I said I wanted to increase the width moving up to a 245 - I assumed this inferred the current was lower i.e. 235 standard
PhilT
C63 AMG Saloon
Haha 285 on a 9.5 rim, Dont do that Max you want on stock 19 is 265, if you upgrade rims to aftermarket 10" rear max is 275.
If you havent used the tyres send them back as you said you need 245/35 for front
renault12ts
MB Club Veteran
2005 W215 CL500.
I have 275s on 9.5 rims...as advised by MB.
