Hi guys looking for some advice here on what else to replace change as main dealers here in Cyprus cannot find anything wrong with the car and its been in 3 times in a month and a bill of 1,5k +.
2012 C63 AMG, M156, 62k on the clock. Always run on 100oct Fuel. Has stage 1 remap which has been on the car for the past 2 years. Only mod on the car is full catless.
This occured around a month ago but now became more frequent. After about 40m-1h drive when i accelerate hard i get the following fault codes and the car seems like it is out of fuel. If i drive at low speeds i can drive it all day with no problem.
There is hesitation, sometimes no acceleration it is un drive able. Clear the codes let it sit for 10 mins drives ok until you accelerate hard again. The code are stored and not current as i have had the car checked at a local specialist also. Last thing i am consider in changing is fuel pumps / fuel filter clogged ??
These are the fault codes i am getting-
-The Fuel Pressure sensor has a malfunction
-The Fuel Pressure im the system is too low
No engine light comes up, just loss of power like i have run out of fuel.
I have replaced the following-
Throttle body gaskets
IM Gaskets
All new bolts
Fuel pressure sensor
PCV Valve
Rocker cover gaskets
8 X Injectors cleaned and tested
If anyone can shed some light my way will be much apprceciated as i have lost faith in main dealer.
IM Gaskets
All new bolts
PCV Valve
