Is it from the front, rear, from brakes , from engine. you will have to give us more or a clue than driver side, as there is a whole lot of driver side and numorous places a knock could be coming from..
It seems like its coming from the engine when at a stand still, its a progressive knocking sound! It was really to see if anyone had ever encountered something similar or knew what it could be
Check the spark plug gaps.
I had a similar issue where at tick over you could feel it through the brake pedal. However the car ran fine once it was going and the knocking was only at tick over. Also didn't throw any codes either
