Stevie1982
- May 8, 2016
- 2014 C63 AMG
So although there are a few c63 gearbox threads around this is a specific question as I'm a little confused and wondering if I'm missing something so,
When in sports plus driving at say 50-60 and the gearbox is in 6th or 7th with a slight press of the accelerator pedal and it will drop to 4th or 5th in an instance. So drops 2 gears at once
In manual mode, same speeds same gears. Pull the down shift and it drops a single gear. Pull it twice and it still drops a single gear. You have to wait for each gear to engage before down shifting again
Question is, is this right? Can you not opt to down shift 2 gears as quick as it does in sport plus by the press of the loud pedal
Or am I doing somethig wrong
Cheers
Cheers
