C63 Milltek secondary cat replacement pipes
scoobytc
Portsmouth
C63
Can anyone tell me whether the Milltek secondary cat replacement pipes are bolt on or do they require cutting and welding as I don't want to start cutting up my standard system if it can't be easily swapped back
TIA
Still need one pipe requiring cutting and welding i think.
TIA
Your profile states that you're in Portsmouth, so your simplest solution would be to see Olly at PCS just up the road in Horndean. He's a forum sponsor, and will be able to advise and/or fit whatever you want. :)
+1
Olly, Jack & Graham are ur guys to go to at PCS!
Highly recommended!
Removal of secondary cats can also be problematic come MOT time. The rules on their removal is quite clear...You'd be wiser to gut them.
