Palmball
Firstly, apologies that this is going to be a long one and a little reminder as to why I have opted to change the suspension on a practically brand new performance-orientated car!
I'm on my second C63 which, although much better than my first one performance and quality wise, just didn't handle as well. The original pre-2010 C63s with a Performance Pack had a stiffer suspension set up that was widely criticised for giving too hard a ride for the UK (but in my eyes, was a perfectly acceptable compromise for the wonderfully flat handling that it offered). In response to this criticism, AMG fitted the 2010-on C63's with or without Performance Pack with standard suspension which, whilst still having a firm ride, generated a lot more body roll. So much more in fact that I had to do something.
I was going to simply fit the official AMG suspension from the older model but when this came in at nearly £1,500, I thought I could get better for the money. So I spent more...well, 50% more! And got what seems to be regarded (by the US AMG forums at least) as the single best modification you can do to a C63 - KW V3 Coilovers. These are fully adjustable - I mean ride height, compression damping & rebound damping. They also have very trick valves to give extremely good control...or so they said!
The question is...what are they really like??
The Supplier / Fitter
Well before I could try them, I had to find someone to fit them who knew what they were doing as I know nothing about suspension set-up. With so many variables on these kits, I wasn't going to start to find out on my own either! So, as I've mentioned before, I chose to use a company called Car Planet Racing (CPR) in Warrington as they came highly recommended and have considerable experience with AMG's...indeed, they're so highly regarded that they're currently developing some new kit FOR Kleeman!
So, after what seemed like an eternity waiting for the Coilovers to be manufactured (they're all made to order), I was duly promised they would arrive and could be fitted last weekend.
Alas, thanks to the terrible service from KW (in that they didn't send the Coilovers where they should have done...to CPR and not the UK importer!), the Coilovers hadn't arrived by the weekend. However, CPR were also upgrading my brake hoses and fluid so I decided to take the car to them and they kindly lent me a beautiful (and I mean it was beaut!) '97 Mondeo 1.8LX. I shudder at the thought of ever having to drive such a poorly maintained car again but I don't think it was strictly meant for 'customer use'!
I went up to collect my car this evening and, with much excitement and nervousness (as I've never had coilovers before), couldn't wait to try the car out.
However, I've got to say that the service given by CPR has been incredible. Firstly, their owner, Max, has called me everyday with an update after the Coilovers failed to turn up day after day. Secondly, as I live 90 miles away, he stayed open for me to collect the car this evening after I finished work. And that's not all...theres more! When I got there, not only was Max waiting for me but so was his chief engineer and the fitter who did all the work on the car. They then spent about an hour showing me all the work they had done, explaining how it works and the benefits I should be feeling from it. They even took the wheels off again so I could take some photo's!
Seriously, I am very impressed by these guys and would wholeheartedly recommend them to anyone for their quality of work and, in my personal experience of the motor trade, unprecedented customer experience.
They sent me on my way on the standard KW-suggested settings and have agreed to do any further adjustment for me as I see fit...but as you'll see shortly, this may not be necessary!
The Drive
When I finally got the car on the road......WOW!
I chose to drive home from Warrington to Leicestershire over the Peak District as they have some very challenging and undulating roads and I can definitely confirm that these KW's have transformed the cars handling. It is FLAT...I mean NO body roll at all at reasonable speeds. Near the limit, there is just enough movement to let you know you are nearing it but I have never driven a car that maintains such strong body control over the dips, crests and rough surfaces that the Peak District roads have. It has no bump steer and the suspension appears to have magically given it much better turn-in and the ability to grip harder for longer.
It's simply much too easy to drive much too fast.... it just seems like the car can cover any surface without being deflected and it simply had everything that I dared throw at it covered.
Now, I'm sure if you drive a 'proper' sports car, particularly a Porsche, then you'll be totally used to this sort of handling but for an 1800kg car to cover ground like my C63 did today, I'm amazed! Here is the first car that I've driven since owning a new-shape BMW M3 a couple of years ago that I reckon can now out-handle a (stock) M3 and handling-wise, I held that car in very high regard.
However, it's not perfect....not yet anyway. For normal driving and at low speeds it is VERY firm. Not bouncy or crashy...no, the suspension is too well damped and controlled for that...but just plain FIRM. You hit a bump, you feel it. You feel it once and thats it...but it's every bump no matter how small.
So, here comes the best bit....and this I am really excited about.
A chap I know from the BMW forum e90post (and who is a moderator on that forum) happens to know a lot of people in the car world and one of these people is a guy who does testing for AMG at the Nurburgring. And my new best friend has arranged for said chap to spend a day setting my car up on and around the Nurburgring to drive just how I want it to.
This is proper bespoke set-up by a guy who probably knows how to do these cars better than most and the day this takes place will be....on Saturday. I drive out tomorrow evening!
So, there is my first update after a couple of hours experience with this fantastic suspension and the great people I've dealt with in getting it on my car. It wasn't the cheapest, in fact it was probably one of the most expensive options I could have gone for, but the difference is incredible.
Now....for more power!
One more thing.....before I go to Germany tomorrow I'm having the Brabus B63 kit fitted so the car will be fully desrestricted!
The thing is, I may not have bothered with it had I known what I do now (hey ho!)....CPR put my car on their Dyno-Dynamics rolling road and, totally standard, the car put out an incredible 506.9bhp. Thats a full 20bhp more than AMG claim and confirms my thoughts that my car feels significantly quicker than the official 30bhp increase that is quoted between it and my old non-Plus (457bhp) model.
In fact, CPR said it was the most powerful 'stock' '63 engined car they had ever dyno'd and put out more than even the SL's in standard tune. Those forged internals must be worth something after all....but I just hope I still get to see a good like for like increase after tomorrow's Brabus kit is fitted!
Heres a few photo's of the suspension (and new brake lines) and how the car looks....it's 10mm lower than standard so theres very little ride height difference although it still had some settling to do at this point...it looks lower in my driveway now!
Front Suspension:
Additional Reservoir on the damper:
Rear Suspension:
The car (sorry, only one I took for now):
The Drive
Front Suspension:
Rear Suspension:
