Gazwould
Viscosity doesn't dictate protection .
...No need to go thicker anywhere , with thicker oil you get more friction and heat with hot spots as slower flowing !
When you call ask them what oil they used first before saying anything. If they answer correctly it's probably just the desk bod typing in the wrong oil but the right one was used in practice.
You can use 0W40. I wouldn't use 30 as it's a bit thin when up to temperature. These engines run hot and need oil to stick on the valvetrain.
229.50 is the specification you need to check for, then either 5W40 or 0W40. Personally, I use 5W as it's a bit thicker when cold which helps stop all the oil draining out of the lifters etc.
Its 229.5 5w40 in mine since new MB spec id get the 5w 30 out and tell them to use the correct oil there is a guy on here ANTHY i think and on his invoice they put diesel oil in his
Cars going back in on Friday for an oil change. Fair play to MB, I asked if they could confirm the oil that was put in the car. They called me back and told me that the tech has put the wrong oil in, as it should be a 5w 40.Like I said, there's a good chance the invoice is wrong. On the one hand you've got garage monkey who knows mechanics and on the other you've got secretary monkey who knows copy and paste.
You would think so!Fairly basic detail at that!
