HI All, - 2014 C63 W204 26k - Slight water leak
Calling on experienced owners for advice.
After returning home from a 50 mile journey I noticed some wet spot patches where I drove into my drive way. I checked under the car and noticed there was water dripping from the rear of the engine bay.
I've put the car in the garage and placed a tray under the drip to identify if it continued. For the last four days it has been sat in the garage and dropping about 5ml of fluid per day. The fluid is clear and doesn't smell so I'm 99% sure its water. I have no warning indicators on the dash highlighting any issues.
I researched some online forums which mentioned it was possibly condensation from the air con system but I'm not so sure if it has been dripping for several days when the car is idle. I'm going to book it in to a MB specialist but I thought I would run it past you guys to see if you have had similar experience which may help settle my nerves?
I've attached some pics to identify the area in question but obviously the leak could be coming from anywhere above.
Many Thanks
Many Thanks
