Not recommended in my opinion, SL is lowered as part of the AMG line modification and is a total pain with speed humps, pot holes and high curb parking.Hi guys, has anyone lowered their c63 on springs for the W205.. Eibach, H&R, KW HAS?
Anyone had alignment issues after as I’ve read a camber kit is needed for the front?
Is yours lowered or standard?Don't know about the technical side of lowering but my 2017 C63s coupe will scrape some speed humps and the same with kerbs if you park too far forward, also have to be a bit careful if the road has an uneven dip.
Doesn't your car have ABC...which you can raise?I know same applies to any lowering, had my mini lowered same issues, simply not worth it for cosmetics v ride quality in my opinion.
Mercedes SL500 R231
No avoided ABC too many reliability issues reported on this forum, it scared me off!Doesn't your car have ABC...which you can raise?
Standard, I know people like lowering but to me the car looks good as it is and UK roads are tricky enough without changing the standard setup.Is yours lowered or standard?
Mercedes SL500 R231
