C63s Alloys
Discussion in 'Wheels, Tyres, Brakes & Suspension' started by LennyA, Jul 11, 2019.
  1. LennyA
    LennyA New Member
    2
    Jul 11, 2019
    Kent
    Car:
    C63s Saloon
    Hi, have currently got a 2017 C63s Saloon with standard 19” Alloys. I am trying to find a set of the black 19” which were a factory option, the only ones I can find are off of a Coupe which are slightly wider and 20” on the rear. Am a bit confused with the offset size etc, does anyone know if the Coupe larger/wider wheels will fit a Saloon? Any help would be ap
  2. AMGeed
    AMGeed MB Club Veteran
    12,771
    Nov 1, 2008
    Bournemouth/Poole Dorset
    Car:
    2014 E63 Biturbo
    I don't think the 20" couple rear alloys will fit. Using the "will they fit" calculator, you can see the 20" alloys would be 30.4mm closer to the suspension strut. It would foul the caliper easily. Also, the outer rim would poke out 20mm toward the wheel arch. Another foul.
    I have used the specs of the W205 Saloon and Coupe alloys to get the ET's and tyre sizes.
    https://www.willtheyfit.com/index.p...=30&wheel_size=20&wheel_width=10-5&offset2=57
  3. OP
    OP
    LennyA
    LennyA New Member
    2
    Jul 11, 2019
    Kent
    Car:
    C63s Saloon
    Thanks for the info, will keep looking for the right size!
  4. 23 Romeo Tango
    23 Romeo Tango Hardcore MB Enthusiast
    667
    Jan 24, 2018
    North East
    Car:
    W213 E63s Edition 1
Share This Page
