Hi All, I’m new to this first time using wondering if someone can help me.
I have a 2016 C63s coupe and was damaged by a friend who was borrowing it.
It only suffered damaged from passenger wheel, coolant pump passenger side and the coolant rad passenger side and also corner of 2 rads at the front one being the main rad and one at the front which is connected to the passenger small rad. The old pump was broken in half (maybe short too) I have now fitted everything brand new from MB. once fitted I filled up both water tanks one on the driver side and one in the middle of the engine.
the one in the middle of the engine didn’t take much water at all considering it was all empty.
I am now worried that the small electric pump isn’t working how as the water isn’t flowing in the small rad on the passenger side any ideas how I can check if it’s working or when does it work? Also if anybody knows if there is a fuse or relay for it.
thank you very much I would be grateful if someone can help
