cabin and air filter for CLK 55 2003?
toffee-pie
Legacy 3.0R Spec.B 6MT
Can anyone point me towards the pair of these needed, I think I will be able to replace both and give my wallet a much earned rest.
thanks.
also
can someone give a ball mark cost for the following,
rear gearbox mount
tranny fluid change
ABC fluid change
supercharge belt change.
That is pretty much all the 'big' work I can see due on the car, are these big jobs?
also
rear gearbox mount
tranny fluid change
ABC fluid change
Try carparts4less for parts... The cabin filter is behind the glove box and is easy to do. Air filters are really easy also, unscrew them from the air box and replace!
Tranny change is around £200
ABC change is around £150 (make sure the filter is replaced with new ones both before and after the fluid is changed)
Not sure about gearbox mount or belt change...
Is ABC fluid change a mandatory item as I cant see it on the service book at all? and the service book is quite detailed by all accounts.
Is there 1 or 2 pollen filters in the cabin? I've ordered 1.
cheers, I will make that SC belt and ABC fluid high on my MB specialist list.
The gearbox mount is about £30 and takes about 1 minute to change if its already on a ramp.
Olly is doing an ATF change offer at his GTG next month at PCS for £145
The s/c belt is almost cost only as its quick to change.
guys
This is top quality help here.
So, I dont need to go to MB to get the ABC fluid done? I know a very very good mechanic here, right next to work. I planned to get him do the SC belt and Tranny fluid, now it looks like I can get him to to ABC fluid also? I don't think he has STAR equipment, is this required?
Has anyone part numbers for SC belt and the gearbox mount?
What type Tranny fluid is used, and brands (also for ABC)?
2 of these will do?
http://www.ebay.co.uk/itm/5L-SYNTHE...UK-/111887807939?_trksid=p2141725.m3641.l6368
I seen this but its USA stock
https://www.blauparts.com/proddetail.asp?prod=F2A1501-E
