I'm attempting to install a RVC and would like to know which is the best route for the cable to the rear of the command unit.
I have a fakra to RCA cable arriving this week, for the command unit.
I intend to run the cable from the boot, under the sills and across to the command.
However, I cannot see an easy way to run from the passenger side under the glovebox. I have pulled down the carpet to have a look, but cannot see any way past the metal protective cover. I know this may need to be removed - i can see two securing points.
Is there a straight forward route?
Any help is much appreciated.
