mrk
After my previous disaster with fuses my 2001 W203 Coupe has been running great. Until I brought it in for a service that is. The mechanic replaced the camshaft magnet saying that it was leaking oil, and he replaced the wiring loom and cleaned it all up. Fair enough. I take it home and then the problems began.
After a week of problems with stalling (revs would drop to below 500 when the foot went onto the clutch) and surging revs when the engine was cold, they replaced the lambda sensor, and things seemed a bit better. At first. The stalling went away, but it's still touch and go now. And then this evening the engine light appeared at the end of a 30 mile drive.
Can anyone suggest what else might be the problem? It's not that i don't trust the mechanic, I just can't afford to keep doing the hokey cokey with this car, as it's been in and out of the garage about 4 times in a week with marginal improvements. I'd rather just ask him to try a few things in succession, but I could do with some suggestions as to what else could be causing it.
Also, what's the consensus about continuing to drive the car once the warning light comes on? I can't do anything until Monday afternoon but really need transport in the meantime. Am I at risk of complete breakdown if I continue to drive it?
Cheers,
Maurice
Cheers,
Maurice
