Guys, thanks again - and sorry to cause a difference of opinion.
As I mentioned, my CL handbook says DO NOT use a jump starter but DO use a donor vehicle. Go figure, as they say on the other side of the pond.
Yes, I'm lucky that I have time and space to take the CTEK route but, if marooned in a car park somewhere if the lock(s) play up again, do I follow the handbook and turn down a jump starter from the breakdown chappie?
And, as for jump starting using a donor vehicle, yes connect leads with no engines running and disconnect with only the jumped car's running.
As an aside, I bought my jump starter after collecting my first auction purchase in 2014 (Sunbeam Talbot 90) when it had starting issues. The first time I connected it - it was dark - I forgot to check the car's polarity ... I knew it was positive earth, but neglected to notice that it had been changed to negative ... cue massive sparks when connecting the earth cable. Subsequently discovered the trafficators no longer worked, so hand signals it was all the way back from Poole to down here .... some 450 miles. Cue much French amusement and then annoyance.
I dread to think what would happen to a modern car if that happened ... perhaps only a few blown fuses or relays, but still a problem.
