Can I lock car if its on trickle charge?
mark_le_b
Jersey
2006 W211 E63 AMG
If I were to plug my car into a battery conditioner (on the under bonnet terminals) - so the bonnet is down but not locked - can I lock the car, or will the car "know" the bonnet is open and cause the alarm to go off?
Try it, most alarms do have bonnet sensor. If it doesnt work take the wires in through the grill if possible or from under the car.
I suspect the alarm would go off. Can you not run the cable through the grille, or up from underneath the vehicle?
Will go up from underneath and close bonnet
Cheers all
i stick my car on the ctek charger often; and lock it before shutting the garage door...
no problems
