mario andretti
Right I am looking at putting an engine from a pre 2000 w202 into a w124. I am looking at how to get around the immobiliser and I am wondering is retro fitting the data communication box and engine ecu and ignition switch going to be enough. My only concern is that the system needs the abs ecu etc before the start command can be given.
The other thing is the electronic steering lock as does this need to be present for the start procedure or will what I have said earlier work for me.
Many thanks in advance for info received
