My question is this: do these cars usually have warning signs and symptoms that the battery is nearing its last days?
The car in question specifically is a 2006 C200 CDI. The battery is a little over 4 years old. A few weeks ago, I've had about 2 instances when I got a low voltage warning on the dash before starting. And about twice the cranking took a bit longer than normally. This was a few weeks ago. Since then no warning or slow cranking.
Today I tested it directly with a multimeter. I turned the headlights on for about 2 minutes, then turned them off. The reading was 12.4 / 12.5 v. When starting the car several times, the voltage would drop to about 9.2-9.8 v.
Although interestingly, afterwards, I monitored the voltage from the secret menu in the dash, and when starting, it wouldn't go lower than 10 v. Maybe thought just because the engine was warmer...
One more piece of information that may or may not be relevant: about half a year ago, we were on vacation and the car was not started or driven at all for about 2.5 weeks, and despite a low voltage warning, it started just fine.
