Twixer
Hi folks, can anyone recommend a battery charger for my 2 years old "A"- Class (fairly simple and not too expensive)
Regards, Ron Fraser
Regards, Ron Fraser
+1 CTEKHi folks, can anyone recommend a battery charger for my 2 years old "A"- Class (fairly simple and not too expensive)
Regards, Ron Fraser
You could have clubbed together and shared!Cheap as chip , I have one , my Dad has one , my neighbour has one
MAYPOLE MP7423 Electronic Car Battery Charger 3.8 A Fast/Trickle/Pulse Modes | eBay
Find many great new & used options and get the best deals for MAYPOLE MP7423 Electronic Car Battery Charger 3.8 A Fast/Trickle/Pulse Modes at the best online prices at eBay! Free delivery for many products!www.ebay.co.uk
The cable isn’t long enoughYou could have clubbed together and shared!
Correct, worth checking.Just one comment......apparently not all chargers/conditioners are kind to AGM batteries.
Most modern generic charger/conditioners can can safely charge traditional lead acid and AGM batteries though, as long as you don’t use the recondioning feature intended for traditional lead acid batteries.
Few generic charger/conditioners can safely charge lithium batteries though.
Correct, it’s the reconditioning mode specifically which is not good for AGM apparently, despite recond mode being available on the AGM setting.My CTEK is 12 years old and has an AGM mode. I recently (double) checked with CTEK and they confirmed that it is safe for my car (in AGM mode).
However, I believe that the OP is looking for something less expensive.....
Mine does not have a reconditioning mode for AGM. Reconditioning is only there for the traditional batteies. It is a 12 year old unit!Correct, it’s the reconditioning mode specifically which is not good for AGM apparently, despite recond mode being available on the AGM setting.
I agree it is strange. The unit allows you to, the instructions don’t warn you not to, but if contacted then CTEK support will advise you not to. That’s in brand new 2020 MX5.0 units too.Mine does not have a reconditioning mode for AGM. Reconditioning is only there for the traditional batteies. It is a 12 year old unit!
It is strange that a manufacturer like CTEK would have a reconditioning mode for AGM if it is harmful to them.
