Hello guys
I am from Bulgaria and I am new to this forum, already registered in other boards, but people there seem to be very unhelpfull (or dumb I can't decide) so I decided to post my 3-and-more months old problem here.
My car ('95 C200 petrol W202, manual, 180K miles on the clock) started acting very strange in the past 3 months. Sometimes, the engine hesitates when the gas pedal is not pressed to the floor. I mean there's no difference between 1/8, 1/4, 3/4, 8/9 throttle ... car just doesn't accelerate at all...BUT when the pedal reaches the floor the car suddenly starts accelerating and runs like a bullet!! When it gets in this condition the idle is just terrible, it cuts out very often. When it is in the mood, it is perfect at all rpms, including at idle.
Things I have done and didn't help:
Changed the ecu (PMS)
Changed spark plugs and wires.
Changed air, fuel filters
Renewed the whole engine harness with new wires, they were very cracked
The car falls in this condition much more often when the air outside is warmer. I say air, because the engine temperature has nothing to do with the problem. Now, when the winter is coming the car is much better.
I changed the ECU because I noticed, that disconnecting the vacuum tube from the ECU makes the car run better and the problem much less noticeable and thought the MAP sensor inside is going bad, but...unfortunately it was not because with the new ecu it was almost the same. Also, the new plugs and wires made it less noticeable but in general it's the same
I hope you guys at least have a clue. I searched everywhere but couldn't find someone with a problem like mine. In another board a guy suggested me to change my Mass Flow Sensor hahaha
