Arrived home last night all safe and sound and without any further incidents. I'll stick some pictures up from the trip soon.
This noise... much harder, but not impossible to hear in the UK thanks to the increased tyre/road sounds/feels mechanical and not from the tyres... I think I misled you all by describing it as a hunting noise and should probably have said more a rasping/grinding noise... only not so grinding as I think something's going to fall off any second. More like a rough bearing would sound/feel.
It makes no difference at all if the car is driving straight or turning, changing lanes or anything else. Which to my mind rules out wheel bearings and leaves the diff and prop shaft... or perhaps the final drive of the gear box? I guess it could still be a rear wheel bearing, but I'd expect some variance in noise depending on weight transfer etc.
Having said that, I did notice the noise disappears completely when the suspension is unloaded... eg hit a bump at speed - which makes me think once again, wheel bearing.
I can hear the noise as low as 20mph and as high as 80mph beyond which the pitch and increased road/wind noise make it disappear. It is loudest in the car with the roof up and at around 50 to 60 mph. With the roof down or the windows down, I cannot hear the noise being reflected from other objects (walls, hedge rows etc.) and other noises such as wind, tend to lessen it, which makes me think it might just be natural resonance in an SL?
Anyone else with an SL noticed something similar?
I'll be speaking to the dealer tomorrow and asking them to check it out under warranty and will of course post back, but I'm concerned I'll get the 'They all do that sir' line.
Regards,
