Cymruambyth
- Apr 9, 2017
I`ve done both (zip merging not intentional) and it can be be dodgy trying to merge when some people just won`t let you!
Yes but it gets the traffic through the restriction quicker forward of where you sit because there is less of it to get through the restriction. I wouldn't mind a bet that Ambulance Drivers are taught to do this in this situation to save those precious moments....
Problem is I suspect it is illegal and according to this article creates a longer tail back.
He's probably right.. BUT road designers tend to forget that people do not work quite as well as their computer models. All of us would love to drive to the end of a dual carriageway that becomes one lane and simply filter in (zipper effect) one car after another, left/right/left/right..after you sir ,just as the lane you are in disappears.A friend who designs roads for a living once told me that their traffic flow calculations are based on drivers using both lanes up to the narrowing point, and that merging early simply increases the tailback for no reason.
Humans don't work that way...
Read that back to yourself & have another think? (Especially about the whole point of the article and why using 2 lanes is quicker for everyone)
Russ
The info I gave is spot on. The key being "forward of where you sit".
.I was thinking of E Services and how they may be taught to get through situations like this, for them if both lanes are not full it is beneficial to block one lane from further adding to the number of vehicles to pass the restriction, this then should then allow them to clear the obstruction quicker by stopping those only thinking of themselves and bombing by....yes...??
Under normal conditions the quickest way through these types of hold up is to approach from the side, the further around the side you approach from the greater priority you will have to move through the restriction in best time, be it traffic or standing in line at an event - it is the same maths that describes the movement.
Had a guy in an Aston try that once - the look on his face was priceless, if you ride parallel to the space between two cars give at least three seconds indication then move if they won't let you in it is illegal so just keep moving across gently till something happens.
So if you give three seconds or more indication you are legally entitled to move into any gap? First I've heard of this; do tell us where the Highway Code or other authority says this.
Do try it with White Van Man in a rusty, battered old Transit; the 'something' that will happen will be damage to your car...
If the restriction is 'standing in line at an event' and you 'approach from the side', you may well invite a punch in the face from somebody who objects to you queue-jumping...
In NZL you are not allowed to deliberately obstruct a turning vehicle in this situation. Are you telling me you are allowed to do that in the UK....?
Never had a problem with vans but I did have some nutter try it on then call the Police who looked at HIS evidence on film and gave HIM the Infringement Notice, that was a classic.
Mathematically correct, I have no doubt, but think again. In the real world, I suggest emergency service drivers are taught to put the blues and twos on. In that circumstance, the two lanes invariably zip-merge to allow them past. Empirical observation suggests this is so.
What makes you think I do this, I'm just telling you the science for the quickest way through this situation.
And, even if I did do it how do you or they know why it was being done.
And, if anybody hit me in the face it may well be the last thing they ever did depending on how hard they hit me.
