Dritherm many moons ago was a Pilkington fibreglass product, how times have changed I guess Knauf took over from Pilkington. Used to be 50mm thick when I sold insulation, but even back then they sold a partial fill cavity system.Not all cavity insulation is bad. You can install DriTherm mass filled in a new build and it does a fab job because it is non absorbent. Used properly it wouldn’t cause any issues whatsoever.
DriTherm Cavity Insulation Slab 37 from Knauf Earthwool 100mm - 6.55m2 Pack | Insulation Superstore®
DriTherm Cavity Slab 37 from Knauf Earthwool 100mm - 6.55m2 Pack from Knauf. (365497). Order Helpline ☎ 01752 692 206www.insulationsuperstore.co.uk
Its a good product because the fibres run longitudinally so preventing moisture from bridging the cavity, when full fill cavity is pumped in, they have no control over whether a moisture bridge is formed or not.
