Hi all,
im hoping someone may be able to shed some light on an ongoing issue im experiencing. i have an E220 (2002 - previous model to new) which has the factory head unit installed - Audio 10. However, its always rejecting most of any CD-R's i insert into the unit. it plays certain model CD-R's but even now its rejecting any new ones i burn on to that model - previous ones still play.
i have read in previous threads that its probably the laser on the unit or the firmware requires updating. The unit plays original cds fine so im assuming the laser is ok which leaves me to the conclusion that the firware requires updating.
Firstly just want to know if any of you folks have had similar issues and what was the solution and secondly how easy is it updating the firmware - is this a main dealer procedure? the only other options i have is replacing the unit or installing a cd changer - which even be a risk of it still occuring.
Any feedback will be much appreciated.
