cd wont eject c class w203 2003
jonkaw
middlesbrough
c240
can anyone help ,looks like my daughter has put a cd into the console on top of another cd(because i cant find the one that was in earlier)it said no disc inserted so she put another one in,how do i remove the comand unit and remove these.
You could try carefully pushing a rounded knife in the centre of the slot while pushing eject, this should push the little wheel against the cd inside.
If this doe not work you will find your answer on Richards site
http://www.mercupgrades.com/
This worked after several attempts,thank you very much,cant beleive i got both discs out without any damage to the unit,thanks again.
