central locking not working - w124
JWC1982
Berkshire
W124 Mercedes 300d - 1992
my newly purchased W124 3OOD doesn't seem to have central locking working at all. The drivers door and passenger door open with the key, is there a solution/common problem here?
JWC
Under the rear seat squab you will find the central locking vacuum pump. Check all the tubes are connected.
Bear in mind I can only talk a good fix!
Hi
can be the fuse, 'C', had that on my 300TD, fuse looked fine at first glance but must have been cracked. I've got the copper ones now, well worth while.
cheers!
Cheers guys, thats my task later on this afternoon!
Cheers
JWC
