ronwyer
Well, I'm now about onto my 4th used pump in as many months to solve an inoperative trunk lock. Today I opened it to go to the store, and upon returning in 30 minutes it no longer works. Same MO yet again. Everything else on the car works fine that uses vacuum, the trunk opening feature just craps out on me.
I have 6 of these, varying model numbers all look the same. They all work at first, then the trunk lock issue comes up. I am assuming the pump runs in reverse to generate pressure instead of vacuum? Sine I am in California there is no water issue. I will open up the pump on one to see what it looks like. Is it possible the pump needs much higher pressure to work the trunk release than to lock the doors? Or is it possible that the doors operate on simply reversing the vacuum circuit to suck them open or suck the other way to lock?
This would not be quite so annoying if the trunk lock button could mechanically open the boot. As it is, the microswitch starts the pump. Mechanical override is only possible with the key.
If anyone really understands the working of this gadget, or if there is a thread on this already to point me to, I'd really appreciate it.
Hoping this forum is a bit more technically oriented than the Benzworld site. I've all but given up on that one.
