Centre bearing propshaft
EuroJohnny
Lymington Hampshire
CLK 200 Kompressor Cabrio, C class AMG Sport
Hi, Not sure if this comes under Engine/Transmission or Suspension so have posted to both. Is this normal? Have re-joined the rebuilt CLK (2005) A209 subframe to the body, everything fitted as it should have. Bolted the flexible coupling/donut to the diff then to the prop shaft. However when it came to refitting the prop shaft centre bearing it hangs a little, no more than 20mm, down from its location point. I would have expected a perfect vertical alignment. No force is required to push it up to tighten the bolts but I notice a very small flex in the donut when the bearing is pushed up. Anyone experienced this or am I being paranoid?
