changing plugs and lubricants
stevegbr
birmingham
mercedes w203 avantgard se a 1.8 2007
i have been told when changing spark plugs on these cars to use silicone dielectric grease on the threads, is this correct.
The dielectric grease is used on the electrical contact between the spark plug lead and the top of the plug - not on the threads of the plug. Not specific to MB. You could put a small amount of copper grease on the threads to stop them seizing.
There's a school of thought that says that spark plugs should be torqued dry. Personally I put a very tiny smear of copper grease (in the olden days we used graphite grease).
I use copper grease on spark plug threads and and also reduce the specified torque setting to compensate for the reduced friction. Torque values are almost always specified for dry threads so when using any form of lubricant it's universally accepted that a reduction in applied torque is required. Just how much reduction is less certain. Some say as much as 40% or 50%. I use 25%.
What brand of plug do you use 190?
The two Japanese makes NGK and Denso or Bosch.
I'v got a SL350 with the 276 engine. I'v read somewhere that the plugs have to be torqued to a specific amount so that the plug is in the right orientation to the fuel injector. Is this correct.
Oops I think I've found the answer to this question further along. Sorry. :rolleyes:
I've got a SL350 with the 276 engine. I'v read somewhere that the plugs have to be torqued to a specific amount so that the plug is in the right orientation to the fuel injector. Is this correct.
Varying the torque might help with indexing to some degree but it's not a good idea. You should use MB plugs and the specified torque or the specified torque and indexing washers if using other makes of plug.
So what was the answer in case someone else finds this thread in future?
Well as far as can tell the plugs do need to be at the right position/orientation with the injector.
