Seems to be every 5000 miles. This is a lot of oil
Thank you.
Olivier
I know but money's really tight, as you I got a mercedes as I can run on veg, so cheaper then running an astra or honda, and there is a lot of things going into the equation...
Cheers.
running on veg i change mine around every 5k. its due a change now actually.
i use halfords semi synth. not very expensive and is just one of the things you need to do if running on veg oil.
Keep an eye on the Kwik-Fit Spanner Controller. Make sure that he opens the correct drain hole (on one occasion he drained my autobox by mistake), that he doesn't overfill, and that he doesn't use his Mr Universe skills to tighten the sump plug (it needs only 25Nm of torque).
"Also, they don't use MB oil filters so no good if the the car is under warranty."
Quite right. They can be persuaded to use a customer-supplied filter, but it takes time and trust. My local lot protect themselves by putting "customer-supplied filter" on the invoice; they are of course paranoid about corporate liability.
I don't use them now that I have Costco membership and therefore access to Mobil 1 at a very keen price.
How much is it for 8 litres at costco?
