Charge Movement Flap Error Codes
haggis0073
gloucester
E220 W212 2013
Hey, So I have a W212 E220 2013 (facelift), I have a engine light on although all power is fine and there is NO limp mode. Codes are as follow
P200A07 - The Charge Movement Flap (cylinder bank 1) has a malfunction. There is a mechanical fault. The status is "Stored & Current"
P200671 - The Charge Movement Flap (cylinder bank 1) is jammed closed. The actuator is blocked. The status is "Stored & Current"
Car seems to drive fine with plenty of power, and idles fine. Anyone had this before that could point me in a direction. Was thinking maybe EGR related with soot blocking flaps possibly?
Hi.
I have the same issue. Did you find a solution to this?
Br
Jon
More than likely you'll have swirl flaps coked in carbon and actuator can't do full sweep
Ok, I will make a cleaning swirl flaps. Thanks a lot.
I got my codes after replacing the intake manifold. I have done adaption but codes are still there.
