charging
jmac200t
c220 w202
Hi i have a w164 2007 320cdi and its not charging but the battery light is not on.
i removed it and gave it to an auto electrician he tested it and gave it a clean bill of health.
anyone have the same problem or similar.:confused:
LvR
South Africa
A160 W168
The current flowing through the charge problem indicator lamp is responsible for exciting the alternator in most cases ....................... if the actual lamp is blown you will have no charge situation.
Does the lamp ever light up before you start the engine? ........... if not you may have found the problem
kid-jensen
Epsom Downs
ML 320 W164
Have you measured the volts on the battery to confirm it's not charging?
What duid you remove to have checked, battery or alternator?
OP
OP
J
jmac200t
c220 w202
Had alternator checked and battery all ok.
Battery light is on when you turn on ignition.
7 volts at battery
kid-jensen
Epsom Downs
ML 320 W164
How long does the battery take to go flat when you're driving?
How does the voltage at the battery change when the engine is running?
190
Cheshire
2009 W204 C180K
7 volts can't be right as the car wouldn't start.
David404
West Midlands
GLE350d (W166)
Try a different multi meter?
Test voltage at the battery with everything switched off.
Start engine, rev a little
Check voltage at battery again
you should expect to see higher voltage with engine running.
