SaRO1321
- Feb 14, 2021
- Location
- London, United kingdom
- C63 AMG W204 Alfra Romeo Giulia Quadrifoglio
Happy Sunday to you all and I hope you're all keeping safe and well.
A bit of relevant background:
2013 C63 - done just over 40K miles
Last service July 2020 (included oil change)
Done only 1155 miles since last service
A couple of days ago when out driving, 'check engine oil level at next refuelling' popped up. It is relevant to point out that when I stopped (I actually needed to refuel), the message then disappeared and nor was it in the service cluster. But around 10 minutes after driving again post the refuelling, the message popped up again. Fair to say that when I got home and parked the car, the message once again disappeared. I would like to add that I didn't check the engine oil just after turning the car off.
So my first question is - should I check the engine oil a little while post the car being driven?
I did though check the engine oil the next day. I did 5 pulls and the readings were pretty consistent. The oil level as you can see in the photos only comes up to the first meniscus, when I believe it should be ideally halfway between the two meniscuses?
I have a really good friend who owns his own repair shop but unfortunately he lives far away. He said his first thought is the cold weather triggering it, but then again the oil is synthetic so that shouldn't be an issue. He did though also say that the relatively low mileage that I've done since the last service could be an issue. He did say this prior to me actually checking the oil level. When I showed him the photos, he said it looks like it needs a little top up.
The car has impeccable service history as it only had one previous owner. I called Mercedes in Stratford and I'm due to go in, in a week. The Mercedes guy said they could check the oil, but it could also maybe be a software update issue. I try and be proactive so I already have 10L of Mercedes AMG high performance 229.5 oil, which I will take with me.
I would really appreciate it if you guys can let me know your thoughts. Should I check the engine oil level again when the car is warm prior to taking it into Mercedes?
Thanks again!
Thanks again!
