'Check tyres, Run flat indicator'
tonykm
:dk:
I had a message (in red) to check the tyre pressures. Following the message warning, I had checked and re-filled air in my tires. But I am not able to get rid of the message warning 'Check tyres, Run flat indicator'. The message does not prompt me to such as '+' for Yes or '-' for No.
Please advise how can I run the flat indicator. I even tried pressing the R (Reset) button next to the instrument cluster, but did not work.
:dk:
The message is badly worded - it actually means that the tyres had a problem - you have now rectified it so therefore need to cancel the message.
Cancelling is also a bit confusing and I can't remember just how you do it - I'm sure someone will be along to advise! I know it is something to do with the + and - buttons
Have to scroll through main menu (the one which shows temperature and next service due) to run-flat reset - press the R button on dash then press + on steering wheel to recalibrate, expect you have already worked that out though if not hope this helps,
