checking the atf
spookycat
essex
clk320 2001
when checking the atf i know engine should be at temperature but does the engine still need to be running to check the level many thanks
Hi spookycat,
Yes, the engine must be running when you check the ATF. Also, it is a good idea to move the selector through all the positions a few times to make sure all the galleries are full. Too much atf can be just as bad as not enough.
