chrome center caps!
Someone told me porkies!
But a good deal and look soooooooo much better than the stale grey ones.
We've listed the part numbers and prices a few times on this forum :)
Is there any way to get the centre caps off without removing the wheels (and pushing them out from behind)?
Easy, get a very thin knife, or a watch makers screwdriver and prise it off. If you do it carefully, you wont mark the wheel.
mobeyone said:
I have just bought some!
Good price?? I think retail at nearly £50? at a stealer?
£22 IIRC from Mercedes Manchester last year. you still saved a couple of squids though.
Excellent, many thanks, just bought a set myself :)
And, having got the old ones out, when you fit the new ones apply a thin film of HMP grease to the plastic spring loaded retainers, or the hole in the wheel itself. Then they really do come out easier with the jewellers screwdriver method.
I suppose if you are changing, scrapping the old ones, and not just cleaning then you could do as I did and that is screw a self tapper half way in and pull them out with a pair of pliers :crazy:
Portzy.
PS. I have some "Heritage" types which are going on my SLK soon so I will have a spare set of the ones in this post if anyone wants them?, ridiculously cheap!, and they wont be self tappered either!. 1st to PM?
Thanks portzy. I had the self tapper plan lined up as a last resort, it would be nice to get the caps out undamaged although I don't plan to re-use them. Obviously not marking the wheels is top priority! First I was going to try de-greasing the caps with meths and using a hot glue gun to bond a short bit of dowel on, to act as a 'handle'. You can normally peel hot melt glue off a smooth surface afterwards without any damage.
Just jack it up and take the wheel off! Only takes 5 minutes a wheel. Gives you an opportunity to clean the crud off the inside too, and inspect the tyre for damage.
Also guaranteed not to mark the centre cap or damage the wheel - I reckon the time it takes to mess around with meths, glue gun and dowel would be longer! ;)
All IMHO :)
Will
I have 1 set of these left for £10 + postage if anyone wants them.
Brand new in the packets.
Now Sold
All IMHO :)
Will
Very wise advice!!! When I changed my centre caps I found that both my rear wheels had bonded themselves to the rear hub, a job I had planned taking 45mins to an hour tops turned into a 3 hour exercise. :rolleyes: I was thankfull I found out in the relative safety of my drive on a sunny Sunday afternoon and not stuck on the side of motorway in the peeing rain, in the dark, when trying to change a flat!
If you're gonna change the centre caps then take the wheels off!! You know it makes sense. :D
S.
Do the wheels come off for any service items? It had a major (C) service a month ago, including brake fluid drain & replace.
Who knows? Just take them off! ;) :p
Sorry :D :)
Will
** update **
Just got mine and changed them in.. 2 minutes!!!!!!!!
How? Get a decent sized screw - peel off the old star and you will find a hole in the middle.
Screw in and pull! simple as!!! and no messing about in the rain!!!!!!!!!
BLING BLING!
Yep mine arrived today too. My old centres didn't have a removable star, so I drilled a pilot hole in each, ran in a self tapping screw, and pulled them out with mole grips.
