Citan High Level Brake Light Bulb Replacement
Never done one on a Citan, but they are most often Led units with non replaceable bulbs. Usual method of removal is from the inside of the panel.
Thanks for your reply. It's incredibly dim so I suspect that it's a small bulb rather than an LED. My plan is to replace it with a brighter LED, I found a video that shows how to remove the lens from a Kangoo so hopefully the Citan is the same fitting.
