CL 420 tappy tappit
Discussion in 'Engine' started by Bechstein, Aug 16, 2011.
  1. Bechstein
    Bechstein New Member
    3
    Aug 16, 2011
    Car:
    1997 CL 420
    New to CL420 ownership and new to the forum so please bear with me.
    The CL420 in question is a 1997 model that has covered 84,000 from new and during the last four years it has covered in the region of 1000 miles a year.
    I have seen similar threads concerning disintegration of the oil feed pipe to the tappits and will investigate however my first course of action was to flush the engine with a Wurth engine flush and fill with a premium 5w40 fully synthetic oil.
    This quietened the noise considerably although it's still irritating with all windows and roof open which is how I like to drive (weather permitting).
    However I noticed in the service history that it has been filled (by Merc) with Duckhams initially and then with Shell Helix and am wondering if my choice of oil was wrong.
    Also, is MB the only source of valve gear if replacement parts are needed?
    Thanks in anticipation.
  2. grober
    grober MB Master
    27,890
    Jun 22, 2003
    Perth, Scotland
    Car:
    W204 C200CDI Estate
    It's possible that the previous owners choice of oil or frequency of oil+filter change was in error rather than yours. A 5w40 fully synthetic should be fine for your engine. The 420 engine of that vintage was rumoured to be harder on its valve gear than its 500 cousin but I would have thought their valve trains to be identical?? Maybe the 420 uses a bit more RPM's routinely or there's a bit more valve lift in the cam profile -- don't know?:dk: It may be a sticky/worn /blocked hydraulic tappet which needs replacing or the problem may be more widespread. I would go to MB for the parts. Be sure to check all these ancilliaries at the front of the engine driven by the poly V belt -especially the tensioner assembly to make sure that noise isn't coming from there.
  3. flango
    flango Hardcore MB Enthusiast
    10,995
    Jun 10, 2008
    Gods own country
    Car:
    Mercedes SLK R171
    If it's the M119 engine I would not put fully synthetic anywhere near it as there have been some compatibility issues when using fully syn in late 1990's cars. A semi syn 10w-40 would be fine, Shell Helix would be my preference.
    As Grober says check all the ancilliaries on the front end just to rule these out, worn tensioners can create a sound very like that of rattly tappets.
  4. jaymanek
    jaymanek Authorised Forum Sponsor Authorised Forum Sponsor
    16,412
    Nov 29, 2002
    Nuneaton Warwickshire
    Car:
    You need to change those oilers... They are cheap to buy and not a massive job to fit either.
  5. jonnyboy
    jonnyboy MB Enthusiast
    2,562
    Nov 27, 2005
    Camberley, Surrey
    Car:
    1991 sl300-24 project,s124 280,w115 no interior, w108 project no engine
    Agree with Jay, easy job if you do them one/two at a time.
  6. OP
    OP
    Bechstein
    3
    Aug 16, 2011
    Car:
    1997 CL 420
    Thanks!
    Many thanks for your tips and advice.
    I have a 200 mile trip to do in the car in the not too distant future.
    Will I cause any long term damage by doing this before I do the repair?
    Judging by the service history this has been a issue for the last few thousand miles.
    Paul.
  7. OP
    OP
    Bechstein
    3
    Aug 16, 2011
    Car:
    1997 CL 420
    Oilers changed and noise gone, although to be honest, the oilers that I removed looked like new.
    Good advice over the phone from Jay.
    Many thanks,
    Paul.
  8. jaymanek
    16,412
    Nov 29, 2002
    Car:
    well done, satisfying eh!
    1 person likes this.
  9. parina
    parina New Member
    1
    Mar 10, 2014
    Bulgaria
    Car:
    mercedes CL420
    Hi, does anyone have the MB part numbers for the oilers?
Tags:
Share This Page
