hi guys anyone know where i can get some shocks for my cl 600 2001 plate?
Feel free to let me know your reg, and ill let you know
Dont suppose you have any for DIW 111?
Are those prices correct?
I thought the C215 series V12 ran the same ABC suspension as the W220 V12.
I know mine were over a grand a corner on my old S600L (2001)
I thought ABC was standard on the 215 CL600?
Look at eBay in the US... I got one for £200 second hand and it was perfect.
Just a quick heads up, alot of ABC struts in my experience will not always exhibit a visual defect e.g. oil leaking, turn rubber boot etc and look 100% ok. They can exhibit non frequent problems associated with the Travel Plunger Sensor which is an integral sensor at the top of each leg/strut, this is a non replaceable part. It will throw the ABC warning every now-and-again and gradually get worse. This is a common reason for people selling struts which appear to be visually fine, but you wont know until you fit, test and run with it for a few weeks. HTH
Oh really... Well so far, so good with mine, might have just been lucky!!! Fingers crossed!
yea it came up afew days after i did it and the front right shock was raised slightly higher than the rest (it was the rear left i changed).
I read before that air can get trapped in the system and it takes a while to come up.... Just circulated the suspension up and down afew times, the suspension adjusted itself automatically, and the warning went straight away... On the US forums other people that have done it have had to do exactly the same thing, its apparently possibly caused by not doing a rodeo as that lowers the car more than it would normally, pushing any air out.
